Go Back   Automotive Forums Car Chat > Cars in General
Old 02-26-2021, 04:56 PM
fla03002 fla03002 is offline
Gas fume smell coming from air vents
So I have been having this problem for a while now. Whenever I have the air or heat on in the car, the smell of gas fumes comes through the vents, it stinks really bad. It’s only when the ac/heat is off or its on recirculation that the smell doesn’t come through. Also, when standing outside even a decent distance away from the car this strong smell is noticeable. One other symptom is a loud humming towards the front of the car. Since this is most likely an exhaust problem, could it mean I have been breathing in carbon monoxide or basically huffing gasoline fumes? How toxic to the health of the driver/passengers is this car problem?
Old 02-26-2021, 08:03 PM
jeffmorris jeffmorris is offline
Re: Gas fume smell coming from air vents
Please check the exhaust system and fuel system for leaks.
Old 02-27-2021, 08:10 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
The smell of gas is different from the smell of exhaust. If you are smelling raw gasoline when the vents are pulling air from the base of the windshield, that likely means you have a fuel leak under the hood. That's very dangerous as there is a lot of heat under the hood and your car may catch on fire. That's very dangerous for the driver/passengers, bystanders, fire fighters, first responders, etc.
If you're smelling exhaust fumes, you likely have an exhaust leak somewhere under the hood as well (exhaust manifold, pre-catalytic converter, flex pipe, down pipe, EGR tube, etc.). This is also dangerous to the driver/passengers for the reason you mentioned.
Either way, you know something is not right with the car and you should either get it fixed or stop driving the car. If it's a fuel leak, it may not even be safe to stop driving the car without getting it fixed.
-Rod
Old 03-19-2021, 09:21 PM
daveshapellSVT's Avatar
daveshapellSVT daveshapellSVT is offline
Specvgini
Cabin filter?
2002 Mustang GT ( 4:10 gears, X pipe, cat back, CAI, Under drive pulley set, Intake plenum, throttle body, Tuned) 13.7@101mph https://youtu.be/btMHZeoZTS0
https://www.youtube.com/channel/UCeu...PX2WMqty2z4aPw
2015 Jeep renegade trailhawk
2017 VW Jetta TSI 1.8T
Old 03-29-2021, 10:18 AM
Wild Orchid's Avatar
Wild Orchid Wild Orchid is offline
I had this issue with a GMC Safari a while back.
When I replaced the "charcoal canister" .
I think it filters the gases from the gasoline.
Old 04-01-2021, 12:40 PM
shorod's Avatar
SHO No Mo
Right, the carbon/charcoal canister collects fumes from evaporation and will introduce them in to the intake when the engine is running. The canister can take on fuel if someone overfills the fuel tank, such as folks who like to round to the nearest dollar after the gas pump shuts off when refueling. Often the fumes from a saturate carbon canister will also be noticeable from outside the vehicle, and usually from the rear of the vehicle.
-Rod
The Following 2 Users Say Thank You to shorod For This Useful Post:
Wild Orchid (04-01-2021)
