Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 12-03-2020, 12:49 PM
heymax heymax is offline
Fan switch issue 2006 Envoy
It all started when I lost #5. Now 1 thru 5 don't work. I replaced the resistor and still nothing. When you do switch to 5, you can hear the resistor clicking. I have checked all fuses. I thought it could be the switch but it clicks the resistor. In the last couple of weeks the fan was intermittent. No clue.
Old 12-03-2020, 12:54 PM
maxwedge maxwedge is offline
A990 racer
Re: Fan switch issue 2006 Envoy
Ok, so do you have power and ground at the blower motor?
Old 12-04-2020, 11:09 AM
Maxwedge, Yesterday, I had to go to the store and the blower started. It works on 1 thru 4 but 5 still doesn't work even though I replaced the Resistor. I'm definitely leaning toward the switch itself as the culprit. Still confused.
Old 12-04-2020, 12:11 PM
A990 racer
Look at the connector on the relay/resistor, they typically over heat and can burn the contacts.
Old 12-04-2020, 01:19 PM
The plug at the resistor is fine. No signs of melting or overheating.
