Old 11-13-2020, 05:10 PM
Shirleyann Shirleyann is offline
starting problem
I have a 98 chevy tahoe that turns over but won't ingage. I have replaced the fuel filter, spark plugs and relay but still won't start up. Any help will be appreciated.. Thank you
Old 11-13-2020, 05:57 PM
maxwedge maxwedge is offline
A990 racer
Re: starting problem
Get the fuel pressure tested, need 60-65 psi. Try spraying carb cleaner into the intake see if it fires. Btw, welcome to the forum.
Old 11-13-2020, 06:05 PM
Thank you for the info.. I will give it a try. I know it's something simple. While trying to start it sounds close then nothing and when i turn the key off it still sounds like it wants to start.. Confusing
Old 11-15-2020, 12:28 PM
so i have a 98 tahoe that turns over but won't start and i have done numerous things but having no luck.. any suggestions?
Old 11-15-2020, 12:55 PM
A990 racer
Ok, did you do what was suggested, if not, this is basic diagnostics.
Old 11-16-2020, 11:26 AM
yes i did.. tested what was recommended. so far everything has tested fine. my next attempt might be the oil pressure switch which is hard for me to get to.
Old 11-16-2020, 11:50 AM
A990 racer
So what happened, still no answer, did it start start spraying carb cleaner into the intake, what is the fuel pressure, key on? If the oil switch was involved, the fuel pump operation would be affected.
Old 12-10-2020, 11:49 AM
sierra3dr sierra3dr is offline
Is there fuel in the tank?
Old 12-10-2020, 11:22 PM
brcidd's Avatar
brcidd brcidd is offline
Fuel, air and spark- the three things you need- which one is missing?
Do as suggested first with carb cleaner---if it still doesn't fire, then electrical issue as in no spark....then .....
I,ve seen ignition switch be hot in "run" but not in "start" positions...the biggest hint was that when i left off the starter it tried to fire.....So I put a 12v indicator light on pink wire at coil-- it was hot only ion "run" went dead in "start"--Bad ignition switch....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
