Go Back   Automotive Forums Car Chat > Cars in General
Old 11-10-2020, 09:14 AM
aleekat aleekat is offline
Buick/GM Smart Guys
07 Buick Rendezvous 3.5. Replaced battery & alternator 2 months ago. Wife got in it and nothing. No lights, sounds etc. I suspected bad reman alternator killed the battery. It was late so I picked her up. I tried to start it and nothing. Went back in the morning to leave the keys for tow truck. Tried it again and same results. Towed home. While watching on security cameras. Tow driver got in it to roll off roll back. Saw the brake lights come on and reverse lights went he was going to neutral. Rolled it off the truck. Wife went out couple hours later and it started right up. Been fine a couple days now. Suspecting a possible ignition switch(not the key tumblers)
Thoughts???
Post back, that's what makes Forums Work.
Old 11-10-2020, 01:16 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Buick/GM Smart Guys
Maybe it wasn't fully locked in park. If it does it again either try to reseat the shifter into park, or put it in neutral and try to start it. Could be a neutral safety switch.
Old 11-10-2020, 01:34 PM
No that's not it. No dash lights, no door chime, keyless remote does nothing, no interior lights. Completely dark.
Old 11-10-2020, 02:06 PM
Stealthee's Avatar
Ah, yeah, ignition switch would be my guess too.
The Following User Says Thank You to Stealthee For This Useful Post:
aleekat (11-10-2020)
Old 11-11-2020, 01:21 PM
brcidd's Avatar
brcidd brcidd is offline
Uh-Errh- Brake lights are NOT on ignition switch circuit. I'd say internal open in battery, or bad battery connection/cable. Or bad ground at block/body.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 11-11-2020, 02:29 PM
Valid point. Guess I'll be chasing cabling.
Old 11-12-2020, 05:04 PM
I was able to check it today. Turned the key and no lights or anything. Went under the hood wiggling cables, etc.(nothing noticeable lose) Power restored. Was able to tighten the side battery terminals a little. Checked the grounds and those are clean & tight. So we'll see if the little tightening was the issue.
Thanks.
Old 11-12-2020, 05:48 PM
brcidd's Avatar
I'm guessing from here an internal battery open...swap batteries with one of your other cars for a day or two...see what happens to either....does the problem follow the battery?
'99 GMC Yukon
Old 11-12-2020, 10:35 PM
I do understand battery issues. Since this only is 2 months old, I don't think so. It could be but doubtful.
Old 11-13-2020, 03:59 AM
brcidd's Avatar
I've seen brand new batteries short out and have open circuits right off the shelf---so testing is your best way to solve your issue. Just because it's new doesn't mean a thing in this day and age.
'99 GMC Yukon
Old 11-13-2020, 12:56 PM
Understand. If it does it again I'll pull it and get it tested. My other vehicles have regular top posts.
Old 11-13-2020, 01:11 PM
brcidd's Avatar
If it is truly an intermittent open circuit inside the battery, it will probably test fine. Last time this happened to me, I walked it in, threw it on their counter and demanded another new battery. They understood the failure mode and replaced it. But it was already a warranty replacement, and they said they could only give me a new battery, with no warranty now! This is Autozone. I had no choice but to walk out with the new battery...but the good news is, it fixed my intermittent no start issues. They did not even test it- just gave me the battery, did not put anything in the computer. I had that battery for about two months before I even put it in my vehicle-- they judged it by the date sticker on the batter.
'99 GMC Yukon
Old 11-29-2020, 09:33 AM
So far no repeat of the symptoms.
Old 12-08-2020, 10:53 AM
slowcarnation slowcarnation is offline
I am so glad that when I logged on one of the first threads I saw was on Buick and GMs. To be completely honest, I have never been a big Buick guy or know much about them, but I did just purchase an '85 Skyhawk (I know, I know, the sportiest car out there) and I just want to make it simply fun to drive. Any tips that pertain to just GMs?
