Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-17-2020, 05:06 PM
Ed G. Ed G. is offline
89 Suburban electrical issue.
I keep blowing ECM IGN 10 amp fuse when key turned to On. Engine cranks fine and disconnecting all engine sensors does not help. Tried removing all fuses and still get my test light to lite up across the ECM fuse contacts when key to On. Been all over wiring - nothing obvious?
Old 10-18-2020, 09:46 AM
Blue Bowtie's Avatar
Registered Offender
Re: 89 Suburban electrical issue.
You can also disconnect the wire harness at the injector pod, and check the connections to the EVAP purge solenoid, and the EGR solenoid.
Old 10-18-2020, 10:39 AM
Thanks Blue Bowtie. I will try your suggestions. Ed G.
