Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 10-12-2020, 11:56 AM
Rmerrill3 Rmerrill3 is offline
2013 Ford Edge SVT interior lights inoperable
Hey All. My 2013 Ford Edge SVT interior lights are not working properly. I can turn on the map lights manually and they work. When I open door, I would expect the lights to come on and they do not. With Headlights on, the PRND1 gear shift illumination does not come on, steering wheel control lights do not illuminate (the controls do work). I've checked all the fuses that seem to be labeled as a possibility. Any thoughts would be appreciated.
Old 10-12-2020, 02:50 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 2013 Ford Edge SVT interior lights inoperable
If the PRND1 doesn't illuminate with the headlights verify you have parking lights. I'm betting you do not. Fuse should be labeled tail for that. I doubt that is the cause of the dome light not coming on with the door. That is likely a switch that that needs moved to the proper setting.
The Following 2 Users Say Thank You to Stealthee For This Useful Post:
Rmerrill3 (12-11-2020)
Old 12-11-2020, 05:38 PM
It was a fuse. 1. The fuse was #12, however only one side of the fuse looked broken. Which was really odd and I have never saw something like that before. Mini fuses look different? I have obviously checked this fuse before this time I flipped it over and it was clearly broken.
2. The diagram of the fuses on the box cover was different than the manual. #12 on the cover was #8 on the box cover. I went by the manual and found it.
Thanks for your help!
