Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 07-04-2003, 11:04 PM
Tri-Turbo Tri-Turbo is offline
pop-up lights died
My pop up lights don't work anymore. I spent 15 minutes manually raising them so i wouldn't crash when i came home from work. I don't know where to start looking for the problem. Is it the fuse or is there a little motor that raises the lights. If there is where is it?
Old 07-05-2003, 04:30 AM
AenimA AenimA is offline
the fuse would be under the dash on the drivers side kick plannel deal, there is a little door pull that out - fuses are all there.
Motors die, but usuaully they slow down before they die.
Your options are, leave the headlights up all the time, hopefull you like this look and dont mind the small gas milage change
or you goto the local junkyard and pull one yourself and install it
