Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 09-29-2020, 09:05 AM
flemijackson flemijackson is offline
having a few issues with my Automatic windows
Howdy I am having a few issues with my Automatic windows.
The driver window doesn't move except if you have somebody applying power toward the path you are pressing the catch. I don't know what the issue is. Will WD-40 work? I would prefer not to include a few on the off chance that it might play with something/just give a brief fix. walgreenslistens
Likewise, the traveler side back seat programmed lock doesn't work - any guidance on that?
Much obliged for looking.
Old 05-22-2022, 07:08 AM
Vanman1720 Vanman1720 is offline
Re: having a few issues with my Automatic windows
I have always used a silicone based spray in all of the window channels if you suspect that is the issue causing the window to bind up. It may also be possible that the regulator cables are starting to fray and are causing a binding concern inside of the door frame, you would need to remove the inner door panel to inspect for this cause.
Old 05-22-2022, 07:09 AM
Sorry, just realized this is a 2 year old post...
