Go Back   Automotive Forums Car Chat > Cadillac > Brougham
Old 09-12-2020, 08:11 PM
SocketB SocketB is offline
TBI Throttle Body
The car stalls when the air cleaner is install over it and when i remove the air cleaner the car doesn't stall and the left side fuel injector spray more fuel then the right side is that normal or are they suppose to spray the same amount of fuel into the engine and when i spray throttle body cleaner into the left side throttle body the engine stalls start the car up again spray again it stalls.
This is a issue i'm have with the car i already change the EGR valve it didn't solve the stalling problem i changed the IAC valve it didn't solve the problem the car has new fuel pump and new fuel filter and new throttle body gasket.
I disconnected the vacuum lines one by one and put my thumb over each vacuum pipe to see is the engine would stall the engine didn't stall.
Thanks
Old 09-13-2020, 06:45 AM
maxwedge maxwedge is offline
A990 racer
Re: TBI Throttle Body
What engine, what year?
Old 09-13-2020, 01:58 PM
It's a 350 engine 1993 Cadillac Fleetwood Brougham
Thanks
Old 09-13-2020, 03:28 PM
A990 racer
Ok, Chevy 350 tbi.. Make sure the harness to the injectors under the air cleaner are not being pinched. Also, possible one or both injectors bad, especially the one that looks wea. You may just be temporarily flooding the engine when spraying carb cleaner into that port.
Old 09-14-2020, 04:35 AM
OK thanks i am going to swap the injectors with the ones from a Chevy GMC 91-95 silverado tahoe TBI throttle body that was rebuilt and fuel injectors don't have positive and negative so it doesn't matter which way the are installed right?
Thanks
