Old 09-03-2020, 05:20 AM
jellyfish1234 jellyfish1234 is offline
Cool Another way to re-calibrate Throttle after cleaning it---programming
Here’s another example for the must process after cleaning throttle body, the car in this case is Buick 2007.
The same as before, choose the correct car model and system, the screen will display info of this car like VIN, OS,sub-OS, fuel system, speedometer, engine diagnosis, HW system......you need to confirm if all the info display is correct and if it’s all fine, top OK to proceed. The whole process take 5-50 mins, so ensure battery level is enough.
This kind of process doesn’t require manual operation like turn ignition on or others, showing that different models have different ways for throttle relearn.
