Go Back   Automotive Forums Car Chat > BMW > General Discussion
Old 07-24-2020, 02:46 AM
jellyfish1234 jellyfish1234 is offline
Lightbulb Compare: Two ways to do window initialization
In some cases that car will ask to do car window initialization, such as when you lift the window manually, auto lifting invalid, window moving choppily, and after replacing components.
I used a Topdon Artipad to finish the process.
First choose the car model, use auto scan or manually choose BMW-3 SEIRIES-F30 chassis
And then enter FRM module->special functions->initialize electric window, the display shows initialization status of the four sides.
Tap on each sides and choose OK to start initialization. Double confirm by press the window button to see if it works.
If the car models doesn’t support this way on Artipad, there is another way to do that manually (for older car models). Press the window button the whole time till it totally closed.
Old 04-11-2022, 02:30 AM
Gazza91 Gazza91 is offline
Re: Compare: Two ways to do window initialization
Your effort putting this info online is much appreciated, thanks.
The Following User Says Thank You to Gazza91 For This Useful Post:
JordyStepho (04-12-2022)
Old 02-12-2023, 10:28 PM
NellyJelly NellyJelly is offline
Smile Re: Compare: Two ways to do window initialization
Thanks for this info, looks really useful
Tags
bmw , initialization , window
