Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 07-22-2020, 06:21 PM
blueguy3 blueguy3 is offline
Monte Carlo not shifting
I have a 2001 Monte Carlo SS limited edition . I have no gears except first and reverse. it will not go into 2nd or any other. a code reader said something about the shifting parameters? I wanted to know if it would be the shifting solenoid. or something I could fix myself
Old 07-22-2020, 07:37 PM
maxwedge maxwedge is offline
A990 racer
Re: Monte Carlo not shifting
Try and post the exact codes.
Old 07-22-2020, 08:09 PM
I do not have the exact codes. this is all the information I have. it is not my car yet I am trying to buy it or thinking about buying it.
Old 07-23-2020, 07:32 AM
A990 racer
Well the shifting is controlled by the pcm, all electronic, no way to pin this down, without the proper info.
Old 07-23-2020, 07:50 AM
okay thanks I'll try to get the code
Old 07-23-2020, 10:29 AM
aleekat aleekat is online now
Unless you can get this DIRT CHEAP, I'd reconsider buying a car with shifting issues.
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
Schurkey (09-26-2020)
Old 07-23-2020, 10:50 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
I'm going to bet the forward band is broke. That requires a full trans tear down to even fix it. With the forward band broke it will take off in 1st and you can manually shift from there, but it wont last long.
The Following User Says Thank You to Stealthee For This Useful Post:
blueguy3 (07-23-2020)
Old 07-23-2020, 01:30 PM
okay thanks for the info
