Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 07-20-2020, 04:07 PM
btatt btatt is offline
2001 gmc sonoma - fuel pump, and sensors
I have a 2001 GMC Sonoma 4.3L. Problems started with the fuel pump. Broke down, had spark, but no compression. Pulled off the bed (the first time) found the hose to the fuel pump had disconnect. Fit the hose back on, bed back on - it happened again. This time attached a clamp to the fitting to limp it back home from the smokies and promptly replaced the pump assembly - minus the electrical component.
It broke down again! This last time had fuel pressure but no spark. I am wondering if there is a bigger underlying problem. Checked the fuses. Fuse blew every time i cranked (no start). Changed out the fuel pump electrical components. Found a short in the air temperature sensor on the manifold. Fixed that and now it starts and runs - but I still don't trust there isn't something bigger I'm overlooking and am afraid of a 3rd towing bill.
Any thoughts are appreciated.
Old 07-20-2020, 04:17 PM
Re: 2001 gmc sonoma - fuel pump, and sensors
Also checked the ground - it's good. And replaced the fuel filter.
Old 07-21-2020, 06:43 AM
Blue Bowtie's Avatar
Registered Offender
If you upgraded the power connector at the fuel pump/tank unit when it was replaced, about the only thing left is the pump power relay. A fresh relay might be good to have on hand.
Tags
air , fuel , pump , sensor , temp
