Old 07-19-2020, 05:09 AM
Ayn's Avatar
Ayn Ayn is offline
Power Steering Leak 2020 ~ 08 Trailblazer
Professionally dx-ed as Power Steering Pressure Hose, Power Steering Return Hose & Serpentine Belt. Cost just under $600 bucks. I still have the exact same leak. What do I do?
Please see photo below of spots on pavement: Front Axel
http://userimages-akm.imvu.com/userd...8478697807.jpg
Old 07-19-2020, 07:22 AM
maxwedge maxwedge is offline
A990 racer
Re: Power Steering Leak 2020 ~ 08 Trailblazer
No info here, where is the leak coming from?
The Following 2 Users Say Thank You to maxwedge For This Useful Post:
Ayn (07-20-2020)
Old 07-20-2020, 05:41 AM
Ayn's Avatar
Ayn Ayn is offline
Please see photo below, thank you.
Front Axel
7/20/2020: New dx is PINION SHAFT SEAL - Remove & Replace - w/Skid Plate Costs $100.
Old 07-20-2020, 04:33 PM
Schurkey Schurkey is offline
Go back to the "Professional", and tell them to get it right this time.
You'd be owed at least a partial refund for the "repairs" already made, keeping in mind that they may or may not have been part of the leak, and of course the belt wasn't leaking but could have been worn. That should have been made clear to you.
Spots on the pavement don't help diagnosis, 'cause we don't know where the vehicle was parked. That could be rear axle leakage for all we know.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 07-20-2020, 04:35 PM
Ayn's Avatar
Ayn Ayn is offline
Front Axel
Old 07-20-2020, 04:37 PM
Ayn's Avatar
Ayn Ayn is offline
That was the front axel. They gave me a new dx and quote today:
Old 07-20-2020, 04:40 PM
So again, you complain to them that their previous diagnosis was faulty, get at least a partial refund, and have them--or someone else--fix the real leak.
No partial refund? Your state will have some sort of consumer protection and/or a department that oversees vehicle repairs. Complain to them, watch the results they achieve.
Clearly, you will need to show receipts and any other paperwork they gave you--estimates, etc.
I don't understand how axle lube can be mistaken for PS fluid. One wonders if you had two leaks, and they fixed one, but not the other.
Old 07-20-2020, 04:47 PM
Ayn's Avatar
Ayn Ayn is offline
They stated that it indeed needed all the stuff they had already done. My daughter tells me that the spots are now smaller than what was made on her driveway and on the pavement in front of her house. However, the leaks make the exact same spots still. They didn't actually charge me for the Serpentine Belt, they adjusted the bill and took it out of labor, in the original estimate.
Old 07-20-2020, 04:58 PM
Ayn's Avatar
Ayn Ayn is offline
That appears to be the case. Please note that this vehicle has been kept serviced and the fluids were relative new... barely a month since oil change and fluids topped off. These leaks started suddenly a couple weeks after last oil change.
Old 07-20-2020, 05:09 PM
That's going to make it tougher--maybe impossible--to get a refund. Apparently, they did fix some legitimate leakage by replacing the hoses. Leaks at the hoses wouldn't be all that surprising given the age of a Trailblazer at this point.
TPlease note that this vehicle has been kept serviced and the fluids were relative new... barely a month since oil change and fluids topped off.
PS fluid and axle lube NEVER need to be "topped-off" unless there's a leak. Brake fluid can be topped-off, but SHOULDN'T be, because low brake fluid indicates that the disc brake pads are worn. Adding fluid screws-up this warning of pad wear. Brake fluid should be FLUSHED and fully refilled at pad-change time, and then left alone until the next pad replacement. (or flushed and then refilled only to the level it was before, if the fluid gets contaminated.)
"Topped-off" does not mean that the fluids were "relatively new". MOST of the fluid would be "old", with only a small proportion of "new" fluid added. Getting "new" fluids requires draining the old stuff; you'd have been charged extra for flushing the various fluids.
The Following User Says Thank You to Schurkey For This Useful Post:
Ayn (07-20-2020)
Old 07-20-2020, 05:32 PM
Ayn's Avatar
Ayn Ayn is offline
Oil changes are made at one of those drive through places, not the shop where the repair was made. So, oil change place just did what they normally do in a full service package. I first went there to get this checked because I thought I had an oil leak and maybe they didnt get a plug or something screwed back in good. They told me power steering leak. All I told the shop was I seem to have a power steering leak. I reckon thats all they checked for and obviously repaired. The second repair will be done Thursday and hopefully, that will resolve this issue. I was just shocked over the exact same spots on the pavement after the first repair. I wasn't expecting that. Again, my daughter tells me the spots are now smaller. I have to believe I did indeed have 2 separate leaks and somehow they were combining prior to dribbling onto the pavement? AARRGGHH! *sigh
