Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
View Poll Results: What should I do with this pump?
Replace 0 0%
Stop air leak 0 0%
Check for blockages 0 0%
No idea 0 0%
Voters: 0. You may not vote on this poll
Old 06-05-2020, 11:37 AM
NimPim NimPim is offline
Lightbulb Mechanical Fuel Pump Stops Pumping Fuel
Hi all. I have a Corolla AE80 with 3ALU engine. It was running with a replaced electric fuel pump since the day I bought it. It s original mechanical pump was broken. Since I wanted it to run in the original way, I bought a new mechanical fuel pump, which is not OEM probably. I installed it correct and re adjusted the float bowl valve so that fuel level inside the bowl will remain within limits.*
At the beginning it did not work. Not a drop of fuel out. Later I used my old electric pump to prime the mechanical pump and then removed the electric pump. Then it was working fine. Fuel outlet gave a good stream of fuel. I ran the vehicle for few*kilo meters and then it stop. I happened to find that the pump is not pumping fuel any more. Once again I primed the pump and same thing happened. I primed the pump for like 5 times and I end up in same problem.*
Is this pump out of order? But it is new.
I used a transparent tube between pump and filter. I happen to notice that air bubbles are drawn towards the pump. Could this be the problem? Should I make sure that no air is drawn in to*fuel lines?
But even if I make sure that no air is drawn, what happens when fuel vaporized once kept sit for a while? Won't there be air trapped inside fuel lines? Shouldn't the pump be able to deal with it?
Tags
fuel , pump , toyotacorollas
