Old 06-01-2020, 08:45 AM
FoxInSocks FoxInSocks is offline
Subaru Engine timing failure - advice
Hi.
Recently got a used 2007 Subaru Legacy (b4) 2L. hardly got a chance to drive it...
The other day, while driving on the highway, it just stalled on me. Stopped on the shoulders, couldnt start the engine. Apparently the timing belt slipped due to a broken bolt or something.
I understand there's a good chance the engine pistons are dead (interference engine) ??
My car shop can't estimate the survival chances, so I dont know if it's worth the money trying to fix it.
Any chances the engine survived that? Would i be wise trying to fix it, or just accept that the engine, and probably the entire car, is a goner...?
Old 06-01-2020, 03:13 PM
maxwedge maxwedge is offline
A990 racer
Re: Subaru Engine timing failure - advice
With the engine no longer timed, a compression test is useless. The problem with the belt must be corrected then a compression test would tell if the engine was damaged internally.
Old 06-01-2020, 10:44 PM
Thanks. I assume so.
But, to fix the timing they would have to extract the snapped bolt, get a new tensioner, possibly open and inspect or replace a few valves... I'm wondering what are the chances the engine will survive after doing all that. It would be a shame to throw more money at it for nothing, and perhaps i should use that cash for an engine swap to begin with.
Old 06-02-2020, 07:55 AM
A990 racer
Correct, it's a gamble. And another engine should have the belt done before installing.
Old 06-02-2020, 11:07 AM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
When, and on which models, did Subaru switch from timing chains to timing belts?
