Old 05-07-2020, 02:55 AM
Schurkey Schurkey is offline
Vibration from 68--78 mph
Just solved my vibration problem...again.
2003 Trailblazer 4.2, 4WD. NOT extended version. Currently 247K miles.
Several years ago, I had a vibration and noise from 68--78 mph. No* shake at 65 or at 80 mph. Worst about 74 mph. Not dependent on power or trans gear--would do it on throttle, or coasting; in OD or D. 2WD or 4WD. Made no difference except for vehicle speed.
This was eventually traced to a faulty rear U-Joint on the rear drive shaft. I had the shaft serviced by the local specialist--they slapped in both U-joints then put the shaft on their lathe. They told me the shaft was slightly bent, but they straightened it--got "almost" all the bend out of it--and balanced it. Reinstalling the shaft, the vibration and noise was G-O-N-E. In fact, the vehicle was so smooth that It was actually better from 25 mph and faster--*I did not realize there was vibration at that low speed until it wasn't there any more!
So several years go by, and my vibration comes back. Same story--68--78 mph, floor shakes, seat shakes, steering wheel is smooth. Vibration is accompanied with a "booming" noise inside the vehicle. Just like before, it's worst about 74 mph. Everything was exactly like the first time.
Except the rear U-joint is fine. So is the front U-joint of the rear driveshaft.
Balancing the wheels doesn't change the vibration. Changing wheels entirely doesn't change the vibration. Rear axle does not seem to have wheel-bearing or differential problems.
I grabbed a rear driveshaft from a 2008 Trailblazer being parted-out. The rear U-joint of that shaft was predictably wiped-out, so I squeezed a new one in myself. Front U-joint is fine. Installed the replacement driveshaft.
Smooth as glass at all speeds. AGAIN, I didn't know I had vibration from 25 mph-faster until it was gone. And the horrible vibration and noise at 74 mph is gone, too.
APPARENTLY, the original driveshaft either went out-of-balance; or the bend came back.
APPARENTLY, the 4WD short-wheelbase GM360 is sensitive to rear driveshaft problems. The extended-wheelbase 4WD rear driveshaft is longer, of course--but it's also MUCH larger diameter than the short-wheelbase shaft. IF (big IF) this vibration ever comes back, I'm having an extended-wheelbase, large-diameter rear driveshaft cut down to the shorter length.
SWMBO is very happy that her ass and eardrums aren't getting massaged at highway speed any more.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
