Old 04-19-2020, 11:31 AM
chevy06burban chevy06burban is offline
Ticking noise
Hello everyone. I have a 93 k1500 with a 350. The other day I started hearing a ticking noise and oil pressure was reading lower than normal. My first thought was low oil, so I checked and it's at correct level. Listening more for where the noise was coming from I could hear in the front of the engine. As it sat idling it suddenly stalled and now won't crank over. The check engine light didn't go on before stalling. After looking in my repair manual, I'm thinking its maybe the timing chain. What do you guys think?
1993 Chevy K1500 Silverado Z71 5.7L 4L60
1972 Chevy K5 CST Blazer 5.7L TH350
Old 04-19-2020, 04:01 PM
777stickman 777stickman is offline
Re: Ticking noise
When you say it "won't crank over" does that mean it won't start or won't turn over at all?
If it cranks but won't start it could be the chain. You can pull the dist cap and see if the rotor turns while "cranking".
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 04-19-2020, 04:16 PM
Re: Ticking noise
It won't turn over at all. Like the battery is completely dead except I know there is juice to the battery since the interior lights and stereo are working. Something to also note is I never had any issue starting the truck up even after the ticking noise started. No hesitation on acceleration thou did have a hiccup like it may have misfired while sitting idle at a stop light kind of like a indication of low fuel. I fueled up as a precaution even thou my gauge said I had plenty of fuel. Got the truck home and popped open the hood to listen closely then after a few minutes that's when the truck stalled.
Old 04-19-2020, 04:28 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Ticking noise
Just because interior lights come on doesn't mean the battery voltage is good and/or connections are good.
Old 04-19-2020, 04:36 PM
Re: Ticking noise
Ok. But a low voltage battery wouldn't be the cause of the ticking noise I was hearing? I would think that if the truck is running and the battery had low voltage the truck would still run off the alternator. Or am I wrong?
Old 04-19-2020, 04:38 PM
Re: Ticking noise
By the way the truck has 102K miles.
Old 04-19-2020, 05:00 PM
Stealthee's Avatar
Re: Ticking noise
Unless the alternator crapped out and killed the battery to where there wasn't enough juice to crank it over.
When it comes to diagnosing an issue you can never assume anything.
Old 04-19-2020, 05:21 PM
Re: Ticking noise
Turn the headlights on and leave a door open for interior lights on. If all that goes out when you turn the key to crank, you've got a bad batt, bad cables and/or bad connections.
57 Chevy 210
Old 04-19-2020, 08:12 PM
Schurkey Schurkey is offline
Re: Ticking noise
"Ticking noise" at the front could be anything from major problems to a rock chip in the fan belt.
The bigger issue right now is why the engine won't crank.
Test voltage at the battery terminals. Fully charged is 12.6--12.7. 12.5 is about 3/4 charged; 12.0 is hopelessly dead.
Charge battery as needed
. Disconnect, clean, and reattach battery cables at the battery. Do the same for the cables at the other end--at the starter or the engine block or wherever they attach. The terminals at the battery, and on the cables, needs to be bright 'n' shiny. Green and fuzzy is bad, BLACK or grey is bad.
Put a long ratchet or breaker-bar and socket on the bolt at the center of the crank pulley. Try to turn the engine clockwise looking from the front. Is the crank locked-up?
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 04-19-2020, 10:47 PM
Smile Re: Ticking noise
Thank you everyone for your input.
@Steelthee you got me thinking when you mentioned the alternator. I've never had one fail before so I didn't know the warning signs. I did a little more research on the alternator. Then I checked the volts on the battery. I was getting a reading of 12.04. Examined the alternator and found metal shavings on the back of it. So I replaced both the battery (that was 6 yrs old) and alternator.
@Schurkey I even cleaned the battery cables even though they didn't really need it. Always a good idea nonetheless.
Turned the key and my truck is running again. The noise is gone.
Again thank you.
