Go Back   Automotive Forums Car Chat > Buick > LaCrosse/Allure
Old 04-10-2020, 11:36 AM
guferuss guferuss is offline
2014 Lacrosse - battery/alternator problem???
Went to start it today, it had a little trouble turning over but started. It then told me "no remote detected" even though I had it in the car. Drove 5 miles, no issue. Restarted 5 minutes later, a message to open/close driver's window popped up, and after I did that it said open/close passenger window. I also noticed it was showing 15-16 volts for most of the trip but eventually reached back down to 14 as I got home.
Any thoughts?
Old 04-10-2020, 10:25 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 2014 Lacrosse - battery/alternator problem???
I'd check your battery connections. If they are corroded it could cause your alternator to overcharge and that can cause a whole host of issues. Overcharging can be worse than undercharging.
Old 04-11-2020, 09:33 AM
aleekat aleekat is online now
Don't trust the gauge. Without a voltmeter you're only guessing. They go for cheap$ now.
Post back, that's what makes Forums Work.
Old 04-12-2020, 07:50 AM
Thanks for the replies. I cleaned the corrosion off one post - it wasn’t too bad - but it didn’t help. Turns out it was the battery.
