Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 04-08-2020, 06:58 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
removed seat, now dash problems
03 sierra. 5.3L
I pulled my driver seat to replace the springs. After reconnecting everything, my gauges weren't working. Eventually they came on (after driving for a few minutes) but this last time I went out to start it, it was slow to start. The tach and speedo still work, but other gauges don't. Also ABS, airbag, and battery lights are on (Check engine is always on due to reasons).
power locks and windows don't work. I noticed that my radio stayed on after I turned the truck off and opened the door (it usually automatically goes off at this point). I manually turned it off and locked the doors.
How would the seat and gauges be connected? Or is this likely just a huge coincidence?
This ain't your grandma's car!!
Old 04-08-2020, 07:34 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: removed seat, now dash problems
You might have shorted something/grounded out something, so I would start checking fuses.
Old 04-08-2020, 08:06 PM
gw84's Avatar
thanks! I'm new to this model, how many fuse boxes are there and would removing a seat really blow a fuse? I guess I should've disconnected the battery first
Old 04-17-2020, 12:38 PM
gw84's Avatar
Update, after a jump, the gauges seem to be back to working properly. Makes zero sense to me but as long as it's working I'm happy. Only thing I hate about these vehicles is you can never seem to fix anything without running into or causing other problems.
Old 04-17-2020, 07:41 PM
aleekat aleekat is offline
If it took a jump, how old is your battery?
Post back, that's what makes Forums Work.
Old 04-19-2020, 06:03 PM
gw84's Avatar
prev owner said it was around 4 years old. Probably due to be replaced.
