Old 07-04-2003, 02:00 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
Another Alternator Problem
Alright well to continue my saga, i finally got that bitch bolt off but now we cant get the alternator out, there is no room, we have already decided we are not taking the head off just to remove it, thats how we got the one off the dx, so anyone have a way from experience to get the alternator out, i was thinking remove the master cylinder but ive never done that and i dont know how to plug the brake lines, people say use cork, but one we dont have cork and two i dont think it would work anyways, any help would be appreciated guys because im stuck at home until we get this shit done.
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 07-04-2003, 02:06 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Is it the stock alternator? there should be room...
I had an oversized alternator put in a while back, and they had to remove the axel to get it in... Changed that out for a smaller alternator, and they were able to just put it in without removing anything...
Old 07-04-2003, 02:09 PM
dude what the hell, i believe its the stock alternator since both that i have are the same size but dude there isnt enough room, the master cylinder sticks out and then on the left side you got the fuel rail and then on the bottom nearest if your standing over the car you have the mount and head, dude i know there aint enough room, in chilton they say remove the air cleaner assmebly but for one thats on the other side of the motor assuming there talking about the air box and two cant get it over there because the back mount is in the way, what the hell!
Say NO to Primer!!
Old 07-04-2003, 02:18 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Just remove the driver side axle. It'll be easier.
Old 07-04-2003, 02:19 PM
ci5ic's Avatar
All the helms manual says is:
If necessary, remove the mount bracket bolts and the upper and lower mount brackets.
Old 07-04-2003, 03:06 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
remove your master cylinder, ive done it 3 times before and it worked, I even put a 5th gen civic alternator thats bigger than the 4th gens, it still fit, it was a tight squeeze and still worked. just move the brake lines out of the way. All the times that I taken off my master cylinder, i never had to bleed the brakes.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 07-04-2003, 05:25 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
DONT DO ANY OF THAT!!! i did this without removing anything. when u get evrything unhooked shove the alternater over to the other side of ur manifold, and you have to push sum hoses out of the way but it will come right up through there. hope it works for ya.
Old 07-04-2003, 06:06 PM
mellowboy's Avatar
Yeh thats what i did but i think its still easier to do it the other way. How did you use the 5th gen alternator when they're obd1??
Old 07-04-2003, 11:10 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Honda says that the quickest way if you know what you are doing is just to pull the axle. If you have done it before, you know it is easy, if the car is level, you shouldn't have any trans fluid come out, and it gives pleanty of room.
Old 07-05-2003, 12:01 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
alternator comes out the bottom, shouldnt have to remove the axle...but it helps....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 07-05-2003, 01:07 AM
well got the alternator out finally by pulling it out the top hella finangling and unbolted the master cylinder but didnt take off brake lines just so that we could move it and it barely fit and it did and im just glad to be done with that bullshit!
Say NO to Primer!!
Old 07-05-2003, 01:13 AM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
if u have a 4th gen cvivic the arlternatorssx siiixxx!!!!! i treplaced like 3 of em!!!!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 07-05-2003, 01:19 AM
hilltopper hilltopper is offline
ouch, glad to hear you got it out, i remember how big a pain in the arse it was to get it out of my sis's 87 rex:P
1999 Ford Taurus - Alternator Problems? Please help! johnosbourn Taurus | Taurus Wagon 11 05-18-2014 12:11 PM
Sorry, it's another alternator question... scottyec76 Rodeo | Passport | MU 24 12-14-2007 01:20 PM
Not another alternator post... 660Ryder Rodeo | Passport | MU 35 02-20-2007 07:34 PM
Another alternator dead gavin_55 General Discussions 1 02-22-2006 01:59 AM
Another Alternator problem, different from other guy :) Xenostalgia Camaro Discussions 32 07-27-2005 06:24 PM
