Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-18-2020, 04:10 PM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
LED Bulb Install Need Resisitor
Swapped out some burned out bulbs on my truck to LED. They are nice and bright but now my flashers are hyperflashing. from what I've read I now need a resistor to stop this. It also says I need one for every bulb on the circuit.
is there any way around installing one on each?
03 GMC Sierra 100k
05 Infiniti G35 150K
10 Mazda 3 Hatchback 110K
16 Infiniti Q50 Red Sport 34K
Old 01-18-2020, 04:41 PM
Blue Bowtie's Avatar
Registered Offender
Re: LED Bulb Install Need Resisitor
It depends upon which flasher is installed. Older models with plug-in flashers could use a "heavy duty" flasher to eliminate the need for a load. many newer models have the flash incorporated into the BCM and/or lighting circuit, and that eliminates the option of simply plugging ing a different flasher unit.
Old 01-18-2020, 06:28 PM
Headnsouth's Avatar
Thx for your reply. I looked around and found that I can swap out the flash module to a Novita LM487 or install resistors on each light. No way I want to do that.
On a different type of resistor you can just clip a wire.
03 GMC Sierra 100k
Old 01-19-2020, 09:22 AM
Registered Offender
Sounds like you got lucky.
