Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-15-2020, 08:29 PM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
Blower has no speed adjustment
Blower motor would not shut off unless I pulled the fuse under hood. I replaced a bad blower motor and resistor on my 03 sierra. start it up and the blower blows but I have no speed control.
WTH? Did I get a bad resistor?
Turns out everything works. Due to the warm engine and outside temperature it functions as it should when went to work this morning. Doh
03 GMC Sierra 100k
05 Infiniti G35 150K
10 Mazda 3 Hatchback 110K
16 Infiniti Q50 Red Sport 34K
Old 01-16-2020, 06:13 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Blower has no speed adjustment
Sounds like a bad resistor still
Old 01-16-2020, 05:47 PM
Headnsouth's Avatar
It may be bad. I'll give it a couple of days and see if it keeps ticking.
03 GMC Sierra 100k
Old 12-07-2020, 06:08 PM
Headnsouth's Avatar
The saga continues... New resistor and it worked for a while. Now it'll cycle on it's own. Replaced it and the same thing. Replaced the AC/heat control module from rock auto DORMAN 599211XD. ran the configuration and it worked for a few weeks. Now it's doing the same thing. Talked to dorman tech support and they say I need a re manufactured 599009. WTH? I took my truck to work this morning and it was in the 30's. Blower worked flawlessly. Got out of work and it warmed up to the 50's. No warm air from the blower at the 70F range but if I cranked it up to the 80's it would get hot. Could it be the temperature sensor? If so where is it?
Any suggestions?
03 GMC Sierra 100k
Old 03-04-2021, 11:49 AM
ctesla's Avatar
ctesla ctesla is offline
headnsouth,
did you get your climate control issue resolved?
was it another bad resistor? or a non-AC one?
or did you get the dorman 599009??
would be nice to know what it was..
i have an 06 Sierra/Hybrid w/140k, and live at
9400ft in the Rockies, so i am constantly using
heater (not so much A/C) for ten months out of the year..
hope you got it fixed, regardless..
Old 03-04-2021, 04:25 PM
Headnsouth's Avatar
Originally Posted by ctesla View Post
headnsouth,
The female side of the pins on the blower resistor were misaligned. I also replaced the DORMAN 599211XD. It was also faulty. So far it's all good.
03 GMC Sierra 100k
The Following 2 Users Say Thank You to Headnsouth For This Useful Post:
ctesla (03-06-2021)
Old 03-06-2021, 08:56 AM
ctesla's Avatar
nice to hear it was a 'somewhat' simple fix..
still a pain to flop around on your backside to get to all of it..
glad to hear it wasn't wiring harness; yuk!
Old 03-06-2021, 11:40 AM
Headnsouth's Avatar
Yep, not the most comfortable position to work in.
Glad to put that project behind me. Especially during the winter months. No defroster and an cold cab makes for a miserable commute.
03 GMC Sierra 100k
