Old 11-13-2019, 01:56 AM
Frah2o Frah2o is offline
1/8 VW GOLF GTI MK2 stance project - COMPLETED
Hi to everybody.
My name is Francesco and I'm from Italy and 41 years old.
I knowed this forum by some link of italian people that are registered in this beatiful forum
I saw and read some fantastic and awesome topic....and the modelling level here is very very high....i love modelling but i'm a newbie/beginner level
I love models and my only scale is 1/8, my favourite model are F1, WRC and self made tuned.
My model are:
Mclaren Mp4/4 1988 Ayrton Senna F1 World Champion 1/8 Kyosho (completed but restoring mode)
Golf II GTI 1/8 Tuned project in progress Hachette collection (first version now dismantled to remade the project)
Lancia Delta WRC 1991 1/8 Hachette (completed)
Lamborghini Countach 1/8 Saleem Hutach next project
Porsche 911 RS 2/7 Track day next project
Subaru impreza S9 WRC 2003 Solberg/Mills 1/8 historical next project
Ferrari 312 T4 J. VIlleneuve 1/8 historical Project
Ferrari F40 Competizione 1/8 in progress
Here some pics of my finished and current work
Mp4/4 finished in first attempt....but now full dismantled for resto mode
Golf II Gti Tuned project....form next post i start this new build diary
Delta Wrc 1991 Biasion/Siviero: my real first completed mode
The Following User Says Thank You to Frah2o For This Useful Post:
Mike94531 (08-22-2024)
Old 11-13-2019, 06:21 AM
Re: 1/8 VW GOLF GTI MK2 stance project - An italian job
I've stated this project 1 year ago, but i must leave it for another timeline project
Finally in the last 3 months i re-started the work on my gti.
Watching the staus, i'm not satisfy of the result reached
I’ve started a tuned/stanced project but i decided to remade it with extra details to try to add more realism to my model.
Here the status
The engine kit i think is a PB engine
Here i started to work on block.
I made hole for engine lift
I scribed the head that was absent
I now repainted the block in iron mica, the head will be painted in allumium block.
Old 11-13-2019, 10:40 AM
I repainted the head with tamiya silver leaf, and whole gearbox and differential in gloss alluminium
I added the missing wire from distributor to ignition coil and i full remade the plug wire with red cable (like Magnecore)
I repainted in green the gearbox cap like on my 1:1 GTI. In the future i'll put a decal vw logo on the gearbox cap.
I dediced to fill the inside wheel arch with milliput to give more deep and cover the flat and toy look plastic
Old 11-14-2019, 01:11 AM
I started the work on engne bay.
The kit give engine bay separeted from chassis.
I "welded" the engine bay and i started to rebuilt the spar that was all wrong in the model (just notched the chassis)
FInally i try a first check for the inside clearence between chassis and and engine.
Old 11-15-2019, 12:49 AM
I continued the work on engine bay. With fiber bond iI filled the self made side pods.
I self made a new water tank bracket with alu stripe and I filled the hole on side strut.
With the help of Lego bricks I made the missed servobrake and i made a new fitting sistem on engine firewall.
I started to selfmade (just finish the final shape) a new clutch lever on gearbox to replicate the future clutch cable (totally missed in the kit)
[IMG]https://uploads.tapatalk-
cdn.com/20190715/27ca834021b116a5cf3fa3af9dd80287.jpg[/IMG]
Old 11-15-2019, 06:43 AM
malscar's Avatar
malscar malscar is offline
Lovely attention to detail Francesco.
The Following User Says Thank You to malscar For This Useful Post:
Frah2o (11-16-2019)
Old 11-15-2019, 08:31 AM
Thanks to much Malscar, I try to do my best.
Old 11-16-2019, 03:12 AM
I coated in primer the engine bay to highlight the faults.
I decided to eliminate the wiper tank. I'll fitted an extra engine oil cooling radiator. I remade a modified radiator and i self made a first version of cooling duct.
Old 11-18-2019, 04:51 AM
I checked the clearence between bonnet and radiator duct...It's too near. I decided to remade a new shape of duct.
I added joint to radiator for future braided hose
I start to modified the inside high beam projector to create a Venturi duct for cooling the extra radiator.
I removed the fluted glass and i fitted a metal mesh. Before to finish this work I need to work the headlight for fit the mesh properly.
At the moment it's all
Old 11-19-2019, 01:12 AM
Before to proceed with other engine or gearbox details, i remade whole engine mount system.
The kit has only 1 (the gearbox and also is not completed) of 3 engine mount.
I remade with my best for my skills, the 3 engine mount.
I reinforced the front struts and i used a modified lego brick to match the right angle for front mount
The rear (timing belt side) was totally missing.
I self made an alu bracket.
The two rear engine mount are fixed on subframe to make easier the future fitting of subframe and arms.
Old 11-20-2019, 01:36 AM
Before continuing with engine bay (missing some ribs on firewall to be replicated) I make some adjustment work.
The oil sump is missing of a parts of block. With styrene I did the new piece (in the next days i’ll paint with color of block)
The timing cover is missing of the rear cover.....with styrene i did also this.
My attention was to the air intake sistem.
I don’t like the oem filter, so i decided to try to replicate the CDA of bmc (that I have really fitted on my Gti mk3)
I modified the intake hose.
With lego bricks i made the MAF sensor and I used the upper control unit from the 1/8 kit.
I finally made the futur carbon box of CDA.
With help of PataFix i fitted all the new system to check clearence and space.
Next step will be:
- fully moulding with putty of hoses and air box
- repainting and use shrink tube for part of hoses
- carbon coating of filter box
- new bracket to fix the new airbox.
Old 11-21-2019, 01:34 AM
I’do my best to give more deep to firewall.
With self made paper template i draw the mouldings.
After cheking the size, i’ll made with styrene and then i fixxed
A fast primer coat to check....i think is quite good and looks like the real firewall
Finally i check clearence with engine an bodyshell....at the moment is good and it's all
Old 11-22-2019, 12:48 AM
I continued the extra add on engine.
The engine (particularly the gearbox) kit is missing of some detail.
I add the check hole for timing on flywheel...then i painted it in green
I replicate a single gear linkage (as like a Delta hf integrale that i build few months ago)
I finished extra detail on clutch leverage
I started to fix timing cover, alternator (which i added a cable) and water pump. I need fitted these elements to adjust the mistake of the kit for cooling and wiring.
I covered with bare metak foil the spark plugs to imitate the original.
Old 11-23-2019, 01:13 AM
I did my personal best to replicate the clutch cable.
With metal wire I did the first visible section.
With a drinking straw, shrink and rubber wire I replicated the clutch cable.
The oil level is orrible from the kit, I remade by myself
I remade the hydraulic joint on the head (i added 2 slot for sensor and future wiring)
Finally i started the work on pulley, i separated them from the printed belt. I’ll made a belt from shrink or elastic.
Old 11-26-2019, 12:45 AM
I continued the work on engine.
I remade the support/radiator of oil filter.
I also add 2 extra joints for extra custom radiator.
The injectors-fuel rail is very poor from the kit.
I added a lego brick to simulate the fuel pressure regulator and 2 joints for fuel lines.
I also added 4 tube that want remember the 4 injectors.
Finally i painted the rail in metallic red and titanium gold the regulator.
To match the 4 injectors to right size i filled the gap between the duct.
I selfmade the vapors oil canister with lego brick, i coated it with bare metal foil; i added the hose level and joint to connect to other joint on rocker cover.
I also fitting the new metal coolant pipes adding the missing hose to waterpump.
I fitted the engine starter and finally I fitted the inlet manifold.
Just some pics in the engine bay to control the fitting and clearence.
