Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-11-2019, 09:58 AM
jjwg3 jjwg3 is offline
2003 Tahoe Transfer Case starts in N/4LO
My 2003 Tahoe with the NP8 Transfer Case seems to be having trouble. It first had pump rub and sprung a leak so I got that changed out. Now whenever the truck is started the 4 button selector switch reverts to either Neutral or 4 LO. I can use the buttons to manipulate it back to 2WD and everything works and drives fine. Next time I start the truck, back to N or 4LO. It seems so odd because it never makes any noise going into 4LO, but you can sure hear the commotion coming back out of it and getting to 2WD.
Would this be the actuator motor? It doesn't seem like its the 4 button switch as they all light up on start up and they all seem to work to do what they are intended to. But shut the truck off and it's back to the beginning.
Thanks for any input, John
Old 11-11-2019, 02:22 PM
777stickman 777stickman is offline
Re: 2003 Tahoe Transfer Case starts in N/4LO
I would be inclined to suspect the T-Case Control Module as the motor seems to do as commanded.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 11-12-2019, 07:11 AM
That makes sense. I'm thinking that's under the dash. I'll start looking into that. Looks like a couple hundred dollar part, not so bad if that would take care of it.
Old 11-12-2019, 09:20 AM
aleekat aleekat is offline
In my older Chevy Blazer it was under the passenger knee/foot panel. I'd be checking for a used one first.
Post back, that's what makes Forums Work.
Old 11-13-2019, 08:34 AM
Used does sound like a cash saver...
Old 04-14-2020, 01:32 PM
Update. I was able to change the control module and while it did seem to help, it still was random where the gearcase would be upon starting the truck. and then one time the switch stopped giving commands and had no lights. Shut the truck off, restarted and was able to tell it to come out of 4 LO and back to driving. So I figured it was the switch itself and changed it, cheap enough.
Unfortunately it still does random stuff about 25% of the time when I start the truck. Now it likes to start in the N (red light) of the switch and sometimes up in AUTO 4WD. But it still occasionally starts in 4LO.
Im baffled. It still takes commands and I can get it back to 2WD to drive the vehicle, but this is getting old. Any thoughts appreciated.
Lastly, could I consider pulling a fuse while it is in 2WD and just leave it disabbled unless I actually wanted to use 4WD? It's very rare for me to use it.
Thanks for anything, John
Old 04-21-2020, 12:28 PM
j cAT j cAT is offline
because this is intermittent electrical issue check the wiring from the under hood fuse box to the transfer case .. the loom breaks down then those very fragile wires do cause the problem..
Old 05-28-2020, 01:09 PM
Thanks for the reply. This is still happening and my local garage can't figure it out either. The wiring loom makes sense, thanks for pointing that out.
Another question, if I have it in 2WD, could I pop a fuse out to ensure it stays in 2WD? I rarely need the 4WD and I have had times when it started in 4LO and wouldn't take commands. That's a major problem!
Thinking I maybe just pull the fuse and stay in 2WD??
John
Old 05-28-2020, 08:39 PM
I would think that YES you could pull a fuse to disable it. Look for a fuse labeled "t-case". Know that doing this will prompt an amber message on the instrument panel.
57 Chevy 210
