Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 11-03-2019, 03:01 PM
dely0575 dely0575 is offline
99 Explorer XLT heater works only on high
My heater only works on high speed.
Old 11-03-2019, 07:16 PM
aleekat aleekat is offline
Re: 99 Explorer XLT heater works only on high
You mean your blower motor only works on high? Usually blower motor resistor.
Post back, that's what makes Forums Work.
Old 11-03-2019, 08:57 PM
65comet's Avatar
65comet 65comet is offline
The resistor is usually mounted in the airbox to keep circulation going past it. Full speed is just passing the full voltage with no resistance. Then each speed below that goes through a greater resistor to take away power and cause a slower fan speed than the one that was faster. Lowest speed goes through the highest resistor causing the greatest heat and least amount of air flow to cool off the resistors. Once one gets hot enough to blow, it isn't long before the rest. Then you are left with just max air speed. Most for that year are under $20 but could varying depending on model. Here is a video on the replacement.
https://www.youtube.com/watch?v=RUJ6Iiun7f4
