Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 09-21-2019, 09:56 PM
Lbruce12 Lbruce12 is offline
Impossible to start the car or unlock the doors
Hello,
I'm wondering if anyone can help me. I have a 2013 ford focus hatchback. My radio isn't working any more so I decided to remove the panel to verify what's wrong. When I removed and unplugged the panel, I saw a thick red line that looked like it's not plugged to anything. I pulled to get it out and it ended up it had power (I know I should have unplugged the battery).
By mistake the cable touched the radio screen, I hear a glitch and then I wasn't able to start the car anymore, I look like electricity doesn't pass. Impossible to even unlock the doors.
Can anyone tell me if he has any idea about the potential electrical failure I've caused?
Please, any guidance would be very appreciated
Old 09-22-2019, 09:10 AM
aleekat aleekat is online now
Re: Impossible to start the car or unlock the doors
Check all fuses.
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
Lbruce12 (09-22-2019)
Old 09-22-2019, 03:04 PM
Originally Posted by aleekat View Post
Check all fuses.
Thank you aleekat for getting back to me. Yes I've tested every single fuse and relay and they're all good. Also, I don'T understand what is the red cable for. It's not plugged to anything. I double checked all the fuses today again. Could I've burned the computer card ?
Old 09-22-2019, 04:21 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
The thick red wire is probably a power wire that used to run to an aftermarket amp.
I doubt you fried the computer. It has nothing to do with the locks and stuff anyway. Sounds more like you have a main fuse blown somewhere.
The Following User Says Thank You to Stealthee For This Useful Post:
Old 09-22-2019, 04:28 PM
It feels a bit reassuring, considering I was expecting the worse. I keep digging but honestly I think I've tested all the fuses. One box under the dashboard, the other one in luggage and the last one under the hood
Old 09-23-2019, 08:40 AM
I just called the dealer, they said it may be a hidden fuse or a cable that burned out.
I tried to find every fuse box I was able to. Any idea witch cable or fuse it could be ?
Old 09-23-2019, 09:05 AM
Pretty sure you have 3 fuse boxes. Glove box area, under the hood and in the trunk. Have you checked them all?
Old 09-24-2019, 06:05 PM
Unfortunatly yes. I'm wondering it there's an aftermarket fuse somewhere but I'm unable to see any
