Go Back   Automotive Forums Car Chat > Ford > Fusion
Old 08-13-2019, 06:08 PM
timd timd is offline
P2111
Daughter's 2013 Fusion has a P2111 check engine code. She's 200 miles away. Possible causes are a stuck-open throttle plate or throttle position. Anyone else have this error code?....and, what was your fix?
*****POSITIVE UPDATE*****
Son-in-law pulled the air hose from the throttle body and found black sludge all over the butterfly.
Cleaned that out, reconnected everything, recalibrated the ETB. Check engine light stayed on until car was driven, engine shutoff and restarted.
The Following User Says Thank You to timd For This Useful Post:
videobruce (11-12-2023)
Old 11-12-2023, 07:02 AM
videobruce videobruce is offline
Re: P2111
To bad no one had any input here, glad you found the problem.
When not in use,turn off the juice!
