Old 07-30-2019, 02:54 PM
George1 George1 is offline
head scratcher
Perplexing situation.
2005 Dodge Grand Caravan SE.
Two problems:
1. Passenger side door electric window switch worked intermittantly. As did the master switch on the driver's door for the right door switch. When the right door switch worked, it was slow.
2. About every 5-10 times I went to start the car I would turn the ignition switch and nothing would happen. Silence. Then it would start. Sometimes it would take 3 or 4 turns before it would start. Most of the time it would start on first try. $$$$$$ to have the problem diagnosed and could be lots more to fix the problem. Decided to live with it as the car would always eventually start. Battery fine but did not run any other electrical system tests.
Soooo-replaced the window switch-$20.00. Starting problem went away. Windows only operate when ignition switch is on of course. Ignition problem started a few months after the window switch started acting up.
Is it just coincidence that the ignition problem seemed to be solved by replacing the window switch or did replacing the window switch actually solve the starting problem?
Thanks
Old 08-06-2019, 04:27 PM
Alphabravo Alphabravo is offline
Re: head scratcher
If I would venture to guess, and it's only a guess, it's that the faulty switch somehow caused the BCM to not recognize your key. Could be that it caused to much resistance, or what have you. But wow, that is bizarre. Either way, I'm glad you got it fixed, even if by accident.
