Old 07-22-2019, 04:59 PM
Ol'Jim Ol'Jim is offline
2008 w/ 4L60E No Forward Gears - Reverse OK
My son's '08 Ext Cab 1500 with 130K Miles, 4.8L and 4L60E trans, failed as he was driving it to work a couple days ago.
I have not had time to go look at it yet, but he described the event to me as follows:
"Was driving to work about 9:30 am, first drive of the day, but it was very warm weather. About 5 blocks from home, slight uphill road, believe it was on the 2-3 shift, I think it had a quick little "shudder" and an immediate Bang or loud Clunk. Felt like it hit neutral. Coasted into a parking lot. Tried all gears. Reverse works. No forward gears are working."
He had it towed home. Said fluid level is fine, no metallic sparkles or burnt smell. Fluid and filter were replaced last Fall, about 7-8K miles ago.
With Reverse still functional, but none of the forward ranges working, this is not one of the common failure modes I am aware of with this trans.
Any advice or guidance on what to look for will be appreciated.
Guessing I will need to begin with a pressure test, then drop pan and look for clues, prepare to pull trans and rebuild.
Thanks, -Jim.
-Jim
2015 Silverado Crew Cab 2500HD 6.6 Duramax 4x4
2002 Silverado Crewcab HD 2500 6.0 4x4 Sold 281K Great Truck
1970 Chevelle SS454 (Gave to my son 9 years ago for his 18th birthday. Yeah, I know, crazy, right? Thank goodness he doesn't drive it the way I would, -er, did...).
1971 Monte Carlo SS454 Drag Racer. The old girl finally got new paint!
1968 Camaro SS (New race car project). Caged, Tubbed, Back-Half/Ladder Bars. Rolling Chassis (For now).
Old 07-22-2019, 09:05 PM
maxwedge maxwedge is offline
A990 racer
Re: 2008 w/ 4L60E No Forward Gears - Reverse OK
It's coming out, no short cut here.
Old 07-23-2019, 09:30 AM
j cAT j cAT is offline
could be a electrical problem... sudden failure no problems prior ..
GM has many wiring problems on these NEW GM trucks..2007 to now..
use GM drivetrain scan tool..
possible Sprag, Forward Clutch... I think it is now made in china ..
Old 07-23-2019, 09:45 AM
j_cAT, that was my initial thought as well, forward clutch/sprag failure.
Good advice on running a scan to possibly identify an electrical issue or other malfunction. Truck did not throw a MIL.
I went over and started it up, tried 1, 2, 3, D - All seemed just like neutral.
No unusual noises from trans. Reverse did engage.
Truck is a 2WD, any particular issues with R & R trans, or is it fairly straightforward?
Thanks guys.
-Jim
Old 08-06-2019, 09:57 AM
No trouble codes showed up on the drivetrain scan.
My son and I removed his trans on Sunday.
Going to rebuild it, freshen up all the soft parts, probably put a new set of bushings in it while it's apart, and see what hard parts may need replacement. I ordered an overhaul master kit specifically for this vehicle, and a new sprag.
Kit showed up, and it says right on the label, it is for "1993-2003".
This truck is an '08. The P/N on it does match what they said I needed, but that label bothers me. I know these trannies underwent a bunch of design changes over the years, so I'm thinking I need to call and return the kit, and try to get the correct one, even if from another source? (Or do you fellas think maybe the label might just have incorrect info in it)?
Thanks for your replies, they are appreciated!
-Jim.
-Jim
Old 08-06-2019, 05:36 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
I know you've already got the trans out, (which is good) but I know from past experience the 4L60E is notorious for a failed second gear. When 2nd fails it goes into limp mode once it tries to shift to 2nd. The failure rate is ridiculous on the 4L60E and that is even in vehicles with engines like the 4.2 I6.
There is a guy semi local to me that rebuilds them on a constant basis and sells the rebuilt ones for $900 plus the core trans. He said he easily sells one a week, if not more.
My brother had a Trailblazer with around 88k miles on it when 2nd just went for no reason.
