Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 07-08-2019, 01:21 PM
cshults's Avatar
cshults cshults is offline
Socket down the defrost vent...
Hi all,
A couple weeks ago I replaced my defrost vent cover and in the process dropped a small socket down the vent. I wasn't worried about it it wasn't rattling around or anything so I just left it down there. Fast forward to now and I changed the air flow setting to defrost and the blend door made a grinding noise and there is barely any airflow from the defrost vent. I can only surmise that this is due to the socket that is now residing in the vent. So I popped the cover off and attempted to fish the socket out with a magnet, but no luck.
So, my question is - Is there an any way to access wherever that vent leads without pulling out the dash? Perhaps from the outside or under the dash?
Thank you
Chris S.
2001 Bravada Platinum Ed.
1992 Beretta GTZ
Old 07-08-2019, 08:36 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Socket down the defrost vent...
Try sticking a magnet to a piece of cable with epoxy that you can twist through the passages. Taking the ventilation apart looks tough.
How about shots of compressed air to the floor vents....maybe shake something loose.
....note to self, keep stuff away from the defrost vents.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 07-09-2019, 11:21 AM
cshults's Avatar
Thanks for the reply, Chris. Tried the magnet trick to no avail, will try the compressed air to see if that'll shake it loose, it's not rolling around wherever it is as I don't hear anything so maybe it's stuck. Might see if I can get a borescope so I can see down in there and locate it.
Chris S.
1992 Beretta GTZ
Old 07-09-2019, 07:43 PM
AF - Advisor
If you hear it close, we are allowed to drill a hole and mend it with gorilla duct tape.
Old 07-10-2019, 02:35 PM
cshults's Avatar
Thanks, Chris!
Chris S.
1992 Beretta GTZ
