Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 07-04-2019, 10:52 AM
Aapanju Aapanju is offline
Car not going past 5000rpm in drive
Hi
I have a 2010 Toyota premio and only 40k km driven.
Car accelerates fine and shifts gears fine but when you hit the peddle under full acceleration it goes up to 5000 rpm than bogs. Won't go over 110km/hr but but if I let of the throttle it will shift gears and speed will go up as long as I am. Under 5k rpm.
Changed spark plugs and air filter.
Changed fuel pump (not entire assembly only pump)
Check catalytic converter and exhaust all ok
No engine check lights etc..
Any ideas what could cause this?
Thanks
Sent from my SM-N960F using Tapatalk
Old 07-04-2019, 12:03 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Car not going past 5000rpm in drive
Check your fuel pressure and fuel flow rate (L/min). You may have a kinked or collapsed line. See how it compares with the spec.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-05-2019, 02:19 AM
All checks out fine... The car accelerates perfect till 5000 before bogging.. Mech says transmission which seems unreasonable. No grinding shifts smoothly... But moment I floor the pedal it'll only go 5000rpm and abou 80kph...if I let go it'll upshift and increase speed.
Weird issue.
Old 07-05-2019, 02:20 AM
I also ended up changing entire fuel pump assembly but no difference...
Old 07-08-2019, 12:18 PM
No one with any ideas?
Old 07-08-2019, 04:18 PM
Brian R.'s Avatar
Resident Chemist
Your ECT button limits your rpm. Try accelerating with ECT enabled.
Old 07-10-2019, 02:14 PM
Car doesn't have an ect button 😭
