Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 06-28-2019, 02:52 PM
SAH SAH is offline
1996 Nissan Pathfinder dies when put into gear
Please help, I am at my wits end,
I have a 1996 Nissan Pathfinder and here is what is going on, Hoping someone can tell me what might be causing the problem.........
(Old not a big issue)
Occasionally would died backing up on a slight grade. (since I've owned the car)
(New, causing a BIG issue)
**I was driving my car, about 8 miles this day, it had a small hiccup issue, like low on gas, but didn't die,
Stopped and got gas, and drove to about 30 miles. No issue.
**Went to a auto store and the drive way is on a slight grade and for the first time in forward motion car died on
the slight hill coming out of the auto , But restarted no problem.
**Drove back another 30 miles coming up the steep hill
the car died, like it just shut off.
**Got it home (towed) , and there was no fire/spark.
**Thought the coil was out but can't just buy a coil, we replaced it with a brand new distributor.
**Car Starts Now
**went to time it with the required unhooking of the TPS.
**Removed top connector of the TPS and NO change, Removed bottom brown connector and the car dies.
**Spec requires TPS to be disconnected when timed.
**Replaced TPS even though it had the proper readings of 5 Volts.
**There is a 12 Volt wire bypass, yellow wire, from ignition switch to the distributor by previous owner, because of dead witer (short) in original wire, NOT a Issue (been driving with this wire for couple years)
**we think the yellow bypass wire was shorted to the intake. So redid wire.
**We had a knock sensor code since we had the car. We relocated the knock sensor and driven the car for a year and a half with NO issue.
**But replaced the knock sensor 2x in the last week because of the code is still there.
**we tested the knock sensor and we have 5 volts to it and 2.5 out of it, so we don't believe the knock sensor is the issue.
**So currently car Starts and Runs and Idles GOOD and Revs Good
**But will died when put into reverse or Drive once it warms up, and sometime when cold but worse when it is warmed up.
**when placed into any drive gear the idle drops under 500 RPMS,
when it is cold and put into gear it stays above 500 RPMS
**IF you can get it into gear you can drive the hell out of it but it will die if you let up off the idle if it is in a gear.
**O2 sensors code but they been replaced in the last year, the codes are still saying both downstream sensors.
**So the scanner we have still shows three codes, the knock sensor and the two down stream O2 sensors.
and another thing, I had a remote start put in the car, the security never worked right, when I tried to lock the the car with the fob the horn would go off, but now neither one of the fobs will start the car, so I was wondering if it could be possible that the remote start could be causing the problem I explained up above?
Thank you all in advance for your help,
Sheila
