Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 06-17-2019, 02:04 PM
tinkering's Avatar
tinkering tinkering is offline
In the 200 Club
Question Adjusting Rack and Pinion Play 2003 Escape
2003 Ford Escape
Do I need to remove the R&P unit from the vehicle to make any adjustments to clear up the slack in the R&P, if there are adjustments available? It looks Awfully tight up/down in there?
It doesn't make sense to me that it might be the inner tie rod ends I'm hearing when I have it on stands and move the wheel side to side.
I can't see in there especially with the flex boot over the joint. It doesn't sound like the inner tie rod end. When I push and pull the wheel from side to side, I hear a clacking almost like a bouncing from behind the fender just forward of the door. This is exactly the same on both the drivers and passenger's sides.
When someone holds the steering wheel still though, I cannot generate that sound at all unless I really give 'er. It's like there is slop instead of preload between the rack & pinion gear... but it doesn't make sense to me; it should make that noise with the steering wheel held still too, shouldn't it!???
1923 Model T 'Stake' Truck, see in Legends of the Fall
1949 Chevy 3/4 Ton, had 214 ci now 235ci
1959 Dodge Mayfair
1986 Ford Ranger 4 cyl
1993 Pontiac TransSport 3.8
1996 Chevy 3/4 Ton 4x4
1999 Oldsmobile Alero
2004 BMW 330i
