Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 06-17-2019, 10:00 AM
LEM LEM is offline
2008 T4R AWD V8 Front Struts or Just Shocks?
4th Gen T4R Suspension Gurus,
My ride has 102k miles on the original suspension. Rides fine, but I'm wanting to replace the front and rear shocks because we tow a camper and well, it's time.
Rear shocks are very straight forward - shocks alone, looks pretty easy with the right tools.
Question is must I replace the entire front end strut assemblies or can I just replace the shock absorbers without touching the springs?
Planning to purchase Bilsteins; their site indicates 4600 Heavy Duty shocks for the front, but these do not include springs.
Please advise...I've never done any suspension work before...
Thanks.
-1990 Mustang LX 5.0L 5-Speed All Stock! except the stereo...
-2005 Yamaha V-Star 1100 Custom
-2008 Toyota 4Runner Ltd 4.7L AWD
-2019 Subaru Ascent (the wife's)
Old 06-18-2019, 10:40 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2008 T4R AWD V8 Front Struts or Just Shocks?
I would base the decision on the ride height of the front chassis. If the wheels are still about the same height below the upper fender as when new, meaning the springs are still strong, I would just replace the shocks. If the front fender is sagging, like noticeably lower than the rear fender, then I would replace the strut assembly - most likely with the Toyota OEM part since it is not substantially affected by towing as compared with the rear. Many OEM parts are available from Amazon. Just get the part number from the dealer part department with your VIN.
In answer to your question, Yes, you can replace just the shock absorber in the front.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 06-19-2019, 11:31 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
If you tow a heavy load frequently you may consider replacing the rear springs as well. Shocks just smooth out the bumps (so to speak) they don't support the load (truck and camper), that's what the springs are for. You're more likely to need rear springs than front.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
The Following 2 Users Say Thank You to fourwd1 For This Useful Post:
Brian R. (06-19-2019), LEM (06-24-2019)
Old 06-19-2019, 09:56 PM
Brian R.'s Avatar
Resident Chemist
Maybe increase the spring rate in the rear. Good catch fourwd1.
Old 06-24-2019, 07:05 AM
LEM LEM is offline
Recommendations for upgraded rear shocks? I tow a 5,000 lb. camper with a tongue weight of around 500 lbs. I do use a weight distributing hitch so there's not much appreciable sag in the rear of the vehicle, still with 102K miles with a good portion in towing, I'd like to consider options.
Thanks
Old 06-26-2019, 09:35 AM
Brian R.'s Avatar
Resident Chemist
Bilstein makes superior shocks for your vehicle.
https://www.amazon.com/Bilstein-24-1...Toyota+4Runner
