Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-12-2019, 08:13 PM
captnwally captnwally is offline
best source for parts
Hi - I just joined the group after buying a 2010 cvpi
Can you either direct me to appropriate forum or give me info on where to find parts for my Crown Vic? Right now I need a spare tire and driver's side airbag (at least I think I need an airbag - the light is on on the dash
thank you in advance
Old 06-13-2019, 04:19 PM
65comet's Avatar
65comet 65comet is offline
Re: best source for parts
It is probably the airbag sensor, but could be a whole bunch of things. When you turn the car on, the sensor light should flash in a sequence, a pause, then another sequence. Flash, flash, flash, pause, flash, flash would indicate a code of 32 and so on. Then you can google that code to see what the computer says it thinks is wrong. Sorry, haven't had that car so can't help on parts.
Old 01-10-2020, 05:06 AM
speeedtrust speeedtrust is offline
How bout https://www.levittownfordparts.com/. Just ordered my tow hitch here.
Old 01-19-2020, 09:13 PM
ramnick ramnick is offline
You can try rockauto for replacement parts.
Old 01-24-2020, 06:33 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Definitely rockauto. Your airbag light will display a series of flashes before it's steady-on. These flashes are the code that's being thrown. The most common cause is the passenger side airbag light being burned out. When you turn the key to the engine run position, that light along with the airbag light on the dash will display for several seconds before extinguishing, or flashing. If the passenger side light does not come on, that will be your problem. It's a grain of wheat type lamp that can be replaced.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
