Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 06-10-2019, 08:24 PM
cshults's Avatar
cshults cshults is offline
Transfer case fluid
Hi all-
Going to change the transfer case fluid and was wondering if it is ok to let Valvoline use their recommended fluid or if only the Trak II is ok to use? For the price, I'd rather just let Valvoline do it, but don't want that to bite me in the butt and will go get the Trak II and do it myself if I have to. Thoughts?
Chris S.
2001 Bravada Platinum Ed.
1992 Beretta GTZ
Old 06-10-2019, 08:35 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Transfer case fluid
I'd stay with the Trac II fluid.
I was going to ask how your New Venture trans case is doing during the most recent thread but I forget things.
My Jeep Grand Cherokee requires a special power steering fluid and even though I can save several dollars with an allegedly ok alternative, I'm staying with the stock stuff.
With a drop in power, I replaced the fuel filter on my Bravada this afternoon, and stink like gasoline to prove it
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 06-10-2019, 08:47 PM
cshults's Avatar
Thanks, Chris. That's what I'm going to do even though I'd rather be lazy and just pay Valvoline the $50 to do the job.
No new transfer case on this Bravada, still the original - maybe thinking of another poster?
Chris S.
1992 Beretta GTZ
Old 06-10-2019, 09:00 PM
AF - Advisor
The name of the transfer case is New Venture, a collaboration with GM & Mopar getting together for a computer controlled, in & out transfer case to save fuel.
The Borg-Warner transfer case with the viscous clutch on the '91-'97 was/is always engaged.
Old 06-10-2019, 09:11 PM
cshults's Avatar
Ahh, got it. Didn't know that! When I originally bought it there was a shudder problem and it was back to the dealer a few times before they figured it out. It was then fine for several years and eventually developed the shudder again so I knew it was time for the case fluid to be changed and now it's been fine for years but now again has developed the tight turn shudder - so it's telling me to change the fluid ��
Chris S.
1992 Beretta GTZ
Old 06-11-2019, 07:11 PM
AF - Advisor
Congrats, evidently you have a good relationship with your Bravada.
Old 06-18-2019, 08:08 AM
blazee's Avatar
blazee blazee is offline
Problem?
Glad to see you're still lurking around the forum and helping out, Chris.
