Go Back   Automotive Forums Car Chat > Honda > General Discussion
Old 07-04-2003, 08:19 AM
DOC-50N's Avatar
DOC-50N DOC-50N is offline
Send a message via ICQ to DOC-50N
Exclamation Electric Window Jammed..
i was just wondering if any1 has had a similair problem and would know how to repair a jammed electric window aya.. its only made it half way wont close fully.. the rubber has worned off probally or need re-alligining.. because the glass window seems off proportioned..? i have to wait a week for my mechanic to get it done damn*.. any1 got some tips.. ive never taken the door into pieces and im afraid that i may accidently ripp my tweeter and speaker cables off in the process..! jus wondering if theres a way to explain how i can get it apart saftly... and how to realign the damn thing
"Imagination is more important than knowledge..."
Albert Einstein
Old 07-04-2003, 08:51 AM
abstract821 abstract821 is offline
I would wait on your mechanic, man. My boy had that same thing happen and he tried to take the door apart and broke the whole f'n window!! I'm sure that it just needs re-aligned, not a big deal. But if you want to go at it yourself, you gots to bust that whole door apart. Wouldn't hurt to get some new rubber for it so it doesn't happen again. Did you try pushing up or down on the window while holding the button?? Just an idea.....
@dam Taylor
Old 07-05-2003, 09:49 PM
BullShifter's Avatar
Sounds like its time for a window regulator & run channel
Old 07-06-2003, 02:47 AM
DOC-50N's Avatar
haha yeah.. i tried and no luck tommoro im gonna ask the mechanic if he can squeeze my car in without appointment..*crossd fingers*! hrmm but yeah the whole window is out of alignment if i forced the window up itll move towards the rear view window and could break the glass cant risk it.. but thanks guys..!
btw i hope your son got his fixed..! its a small thing but the inconvenience becomes great!! :P
Albert Einstein
Old 07-30-2003, 11:26 PM
CivicLeader's Avatar
CivicLeader CivicLeader is offline
Send a message via AIM to CivicLeader Send a message via Yahoo to CivicLeader
What's up DOC-50N...
I'm going to keep this short because I just got kicked off after I typed a few paragraphs....note to self: don't try to post when logged in under hotmail!
Anyhow...had the same problem and I took my car to Honda (I advise the same) and they told me that it could be a multitude of things but start simple....
They shot the guides with some silicone, put the window back on track, and I haven't had any problems since...it cost me like $17 bucks in labor ...no charge for the silicone...and he told me to about twice a year...and maybe more in cold/raily months... to give it a shot just to keep it "lubed" up....
keep it simple and cheap....
CivicLeader...
Old 08-05-2003, 07:34 AM
DOC-50N's Avatar
thanks civicleader.. i actually just had it done from honda..! we tried the mechanic twice and the job only lasted a week,, so yeah honda was the way to go.. i was luky they dint replace nothing they said the problem was the wiring of the speakers.. haha got caught into the winder or somfn..! but yeah.. i can see the rubber needs replacement.. so gotta save up a lil $$ for that to make sure it will never happen again.. for the mean time its cool.. and i keep it lubed as muc has i can after wash!,,
Albert Einstein
Old 08-05-2003, 05:01 PM
No worries DOC-50N...I try to help when I can and if it's cheap and simple...the better the fix.
CL
Old 10-06-2003, 08:49 AM
riccimangan riccimangan is offline
Re: Electric Window Jammed..
Sounds like the teeth on the motor are worn, if the motor is turning even though the window isn't moving then this is the case. your speakers are attached to the door, not the door panel so you should be able to take it apart easily without damaging them....
89 ford bronco 2 electric windows bigd428 Bronco 0 09-13-2010 09:25 PM
1998 Jeep Cherokee Classic - Electric Window Issues Dre1989 Cherokee 1 06-17-2010 12:57 PM
Window Jamming, Electrical Issues Doug91 Deville 0 08-11-2008 04:04 AM
Window Jamming, Electrical Issues Doug91 Deville 0 08-11-2008 04:00 AM
Jammed electric window DOC-50N Engineering/ Technical 2 07-05-2003 12:24 AM
