Go Back   Automotive Forums Car Chat > Cadillac > Fleetwood
Old 05-18-2019, 03:28 PM
trevrek15243 trevrek15243 is offline
350 5.7 Swap in 1966 Fleetwood
I am having the original engine sent out to be rebuilt however that will be a long process because of cost. However, I have a 1994 GM truck with a 350 small block in it. I was wondering if it is possible to swap in the engine and trans from the GM truck into the Caddy temporarily. I don't know if the engine can run without the wiring harness or if I can just use the engine bare bones since the old car doesn't have a lot of wiring, to begin with. If any car guys have worked on this engine before it would be a lot of help.
Old 05-19-2019, 12:39 PM
maxwedge maxwedge is offline
A990 racer
Re: 350 5.7 Swap in 1966 Fleetwood
Major undertaking, not feasible for a temporay repair.
Old 05-20-2019, 09:15 PM
Blue Bowtie's Avatar
Registered Offender
I believe that could involve a new/modified crossmember due to the trans mount location, a different driveshaft (custom), and adapter engine mounts. The exhaust would also be custom. The engine could be made to run with a mechanical/vacuum advance distributor and a carb and matching intake, and probably not a lot of other modifications.
