Old 04-19-2019, 09:34 PM
cjb108 cjb108 is offline
S10-Adj. Fuel Pressure Regulator?
Can anyone tell me if a rich-running condition(P0172) on a '96 2.2L S10 can be cured by adjusting the fuel pressure lower than the factory pressure?
Old 04-20-2019, 08:33 AM
maxwedge maxwedge is offline
A990 racer
Re: S10-Adj. Fuel Pressure Regulator?
If it is in spec, look for something else.
The Following User Says Thank You to maxwedge For This Useful Post:
cjb108 (04-23-2019)
Old 04-20-2019, 12:03 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
As stated look elsewhere. Attempting to fix something, by changing something else that will affect other things is not the way to go. If its running rich, figure out why its running rich and fix that. Order of operation goes diagnostics, fix.
The Following User Says Thank You to Stealthee For This Useful Post:
cjb108 (04-23-2019)
Old 04-23-2019, 11:58 PM
You're both right, of course. I DO know better, It's just that I've tested all the possible causes of this problem as best I can, to no avail.
Thank you both for your input and wisdom
