Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 04-14-2019, 10:27 PM
Jennstoosweet Jennstoosweet is offline
2004 Envoy Won't Start After Fusebox Replacement
Hi, everyone.
I recently purchased a 2004 envoy that had the fusebox under the hood short out and melt. I replaced the fusebox with the exact numbers as the old fusebox. Most of the wires in the two blocks I replaced were able to be reconnected, but around 10 needed to be spliced. After doing this, everything works, but the engin won't turn over and start. Battery was tested and is good. Replaced the main fuse connected to the fuse box and everything seems good, but it won't crank.
Could someone please help me out? I'm completely at a loss. Thanks in advance.
JB
Old 04-15-2019, 10:41 AM
aleekat aleekat is offline
Re: 2004 Envoy Won't Start After Fusebox Replacement
You need to check if you are getting 12v to the starter. So what do the dash lights do when you try to start?
Post back, that's what makes Forums Work.
The Following 2 Users Say Thank You to aleekat For This Useful Post:
Jennstoosweet (04-15-2019)
Old 04-15-2019, 07:48 PM
Hi. Thanks so much for replying. When I turn the key, it acts like it's trying to start, but it like it's not getting the signal. All the dash lights are working. I even tried leaving the key on and jumping the started. It turns over, but won't fire.
Again, thanks so much for your help.
