Go Back   Automotive Forums Car Chat > Cars in General
Old 03-30-2019, 10:44 PM
ufsi7259 ufsi7259 is offline
please help with the wheel key
Hi,
I have a wheel key that is damaged (I guess one of the previous mechanic used too force tighten the bolts).
How, it is not 100% fit for 1-2 of my wheel bolts so the auto mechanic doesn't want to risk removing it.
I am wondering where I can get a replacement or asking for guidance how I can remove the wheel bolts safely with this wheel key.
Thanks!!
Old 03-31-2019, 09:21 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: please help with the wheel key
It doesn't appear that the lug bolts are rounded or significantly damaged, which is good. Apparently and logically the bolts are made from stronger material than the tool. These appear to be standard hex/Allen bolts so finding a replacement tool should not be too difficult once you determine the hex size for both the lugs and the lug wrench with your vehicle. If these are factory provided lug bolts, then the search should be even simpler. If these are aftermarket lugs you may start with a tire shop that sells aftermarket wheels and lugs.
-Rod
Old 04-01-2019, 11:11 PM
beepbeepph beepbeepph is offline
I think you need to know its appropriate size. For a safe process, my suggestion would be to have it checked and change to your trusted car service expert to ensure a safe and reliable process. Hope this helps!
