Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-04-2003, 02:48 AM
hondaisgood hondaisgood is offline
which head which block?
b18 head + b16 block OR b16 head + b18 block
Old 07-04-2003, 03:03 AM
which one is better performance wise?
Old 07-04-2003, 03:16 AM
mayb no post cuz no one knows what im talkin bout?
im talkin about to make a ls vtec
Old 07-04-2003, 07:28 AM
Sid77 Sid77 is offline
The best performing ls/vtec ive heard of is a b18 bottom end with a b16 or ITR top end.
Old 07-04-2003, 03:52 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
u might already know this...but the b16 is the ITR top end. jus has a few different parts on there, but the basis of it is the b16 head.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 07-04-2003, 05:27 PM
PWMAN's Avatar
PWMAN PWMAN is offline
Yeah B18 block with B16 head is best. Or ITR head like krnxracer said, same thing but probably more expensive.
Old 07-04-2003, 09:43 PM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
I want to do this also but am kind of clueless. The B16 head would be off a 99 or so Civic Si? Also, is this a job that I could possibly do just by taking note of how everything goes together, and putting the B16 head on myself? Or is there a silly amount of wiring and jerry rigging that must be done? About the most advanced thing I've ever done is changing springs/struts, and timing belt.
Old 07-04-2003, 09:54 PM
PWMAN's Avatar
I wouldn't do it, LS/VTEC has been proven unreliable on a stock engine. Now if you built it up with aftermarket stuff, that would be different.
Why don't you just go turbo, that is ideal for an LS teg.
Old 07-04-2003, 10:00 PM
loesch8102's Avatar
Wouldn't it be cheaper though to find a junkyard motor and steal the head off it? Plus I wouldn't think it would be any worse for a motor than forced induction would be? I'm not pointing fingers, just making educated guesses.
Old 07-05-2003, 07:09 AM
PWMAN's Avatar
Even running something insanely low like 5-6 PSI is going to get you more power then ls/vtec. You can run 12 PSI safely on a stock LS engine on pump gas.
Any time you tamper with an engine by taking it apart it always to to screw stuff up. Just my experience. Especially since you don't really know what you are doing. Putting on a turbo kit is WAY easier than doing an LS/VTEC. You would be better off, trust me.
Get a turbo kit and run like 8 PSI, forget VTEC.
How many miles are on your car?
Old 07-05-2003, 05:23 PM
loesch8102's Avatar
Probably too many. Like 94,000. I'll just scrap the idea then until I'm done with school. I don't have $3,000 to put a turbo in it.
Old 07-05-2003, 05:59 PM
PWMAN's Avatar
94K is not many miles to a Honda, most last well over 200K. Here's how my philosophy works when it comes to boosting-
1.Less than 50K-safe to boost 12 PSI
2. 50-100K-safe to boost 10 PSI
3.100-150K-safe to boost 8 PSI
4-Over 150K-Not worth risk of blowing engine up
These are very safe numbers, I've seen 12 PSI boosting on an LS with over 100K still going after 2 years. Now has 125K or something like that.
Old 07-07-2003, 12:09 AM
Wants_A_Lude Wants_A_Lude is offline
Send a message via ICQ to Wants_A_Lude Send a message via AIM to Wants_A_Lude
wtf is doesnt matter how many miles are on the engine and the safe PSI to run on it. If the motor was well taken care of, and a compression and leak down test prove that, then boost the normal safe limit. but 12 psi on the stock motor sounds like a bit much to me...
97 Frost White Integra GSR
*94-95 GSR Wheel & Kuhmo Tires
*Type R shift knob/boot
*Pioneer Deck & Doors
*200 Watt MTX Amp & 12" Kicker Comp
Old 07-07-2003, 06:53 AM
PWMAN's Avatar
Oh so your saying it's just as safe to boost a 200K car VS a 20K car? Go ahead and try it moron.
12 PSI is plenty safe, for this particular engine-B18B1/B18A1. 14 has been done before, 12 is the ''safe'' limit. The normal standards for stock internals-12 PSI on the pistons, 14 PSI on rods, and 15 PSI on stock sleeves.
If you don't know what you're talking about then don't question what I'm saying.
