Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 03-16-2019, 12:15 PM
wdchparks wdchparks is offline
Trac Light No Check Engine Light
2013 corolla automatic 4 cyl
Had windshield replaced got car back trac light on, abs light did flash a couple of times then went out. There are no codes showing. Disconnected battery and reconnected after a short period, Trac light still on.
Don't know where to look any ideas
Old 03-16-2019, 06:46 PM
Re: Trac Light No Check Engine Light
so searching the web looking at other models that may have had the same problem none are ever the same exactly seems with mine.
The ABS light flashing and no codes on ABS or Engine that it could be Brake Job Wheel Bearing (had this on another care and it set the ABS light so thinking this not the issue) or Wheel Speed sensor wire.
Nothing happened to this care prior to this problem occurring, except them changing the windshield.
Will be doing brake job next weekend and examine everything in the wheel well area when doing it
After that the tests may get beyond my testor
Tags
light , trac
