Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 03-02-2019, 04:24 PM
WHTrouten WHTrouten is offline
Post 07’ Yukon XL heater
This is new,
I had my engine, 5.3 liter changed. Heat worked fine beforehand, but now doesn’t. Since getting it back, I’ve done a radiator flush, this helped for about 10 minutes, then I put the cap back on. I kid you not, by the time I got back into the truck, it was blowing cold again.
I thought maybe I had to “ burp” the system some more, so I took the cap off again, kept it on high heat defrost and temperature, and ran it another 30 minutes. Same thing, within seconds after putting the cap back on, cold.
Has anyone heard of such a problem?
Is this the heater core going bad or what?
Any help will be appreciated.
WHTrouten
Old 03-02-2019, 08:47 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 07’ Yukon XL heater
Might have an air pocket in the heater core. Take the heater hoses off and run a garden hose through one way, then run it back through the other.
Old 03-03-2019, 07:37 AM
brcidd's Avatar
brcidd brcidd is offline
Direction of flow may have gotten reversed with new engine install. Although it should not be a big deal-I have seen it fix your problem by reversing the hoses at the firewall.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-03-2019, 07:46 AM
Blue Bowtie's Avatar
Registered Offender
Actually, it might make a difference. If there is air in the system it might be better to have the return line at the top of the core, so at least the pumped liquid can fill the core and eventually start some flow into the pump suction line.
Old 03-03-2019, 08:09 AM
aleekat aleekat is offline
If you are going to go ahead and remove the heater core hoses and flush. Put some white vinegar in it and let it sit over night. Then flush again. Most refill the core with antifreeze before putting the hoses back on. It will help to eliminate air pockets.
Post back, that's what makes Forums Work.
