Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 02-22-2019, 10:20 AM
ken288 ken288 is offline
A/C condenser won't engage
2009 Ford Escape
Same as my earlier post, Engine fans are running all the time and dial setting one on inside blower fan doesn't work.
But, I just noticed the condenser motor clutch never engages.
So, I checked;
Freon level looks good even with the clutch not engaged.
Fuse is OK
Fuse block is good. (Not sure what it is called)
How do you check the A/C low pressure switch?
Old 01-08-2020, 09:11 AM
timd timd is offline
Re: A/C condenser won't engage
Visually check that the bolt in the center of the clutch pulley is present. The bolt coming out is a known problem. Hope this helps. Please update if you solved the problem.
Old 01-28-2020, 12:22 AM
ramnick ramnick is offline
Sounds like a bad clutch.
