Old 02-06-2019, 10:08 PM
Whats wrong now Whats wrong now is offline
2012 sil. P0300 P0131 p0137 p0171
I have a 2012 Silverado 1500 LT 5.3 it has a rough idle codes are permanent wont clear with scanner or disconnecting battery.
I change the bank 1 O2 sensors up stream and down steam (yes yes i know what was I thinking) i did have a exhaust leak before the cat Fixed that too think it would fix it but it didnt checked grounds wiring. Cleaned the other o2 sensors PLEASE HELP!
Old 02-07-2019, 08:40 AM
maxwedge maxwedge is offline
A990 racer
Re: 2012 sil. P0300 P0131 p0137 p0171
Welcome to AF. The p0300 misfire is causing a lean exhaust, this can set the 02 codes. Got to track down the misfire issue.
The Following 2 Users Say Thank You to maxwedge For This Useful Post:
Tech II (02-07-2019)
Old 02-07-2019, 03:34 PM
I switched out the O2 sensors upstream and downstream now i got just got codes p0171 and p1133
Old 02-07-2019, 04:16 PM
A990 racer
No more rough idle? Check this link. https://autoservicecosts.com/obd2-codes/p1133/
