Old 02-05-2019, 08:18 AM
spellman1989 spellman1989 is offline
No power
So the problem I am having is with my grand am gt. One day I went to get gas and went to cut it on and had no power. It happened the day before also but I took the battery and had it charged and it started up. I took the battery and had it tested they said it was a good battery and was fully charged still but I still have no power. What else should I check? Could the battery be bad despite reading and testing good?
Sent from my SM-J727T1 using Tapatalk
Old 02-05-2019, 08:30 AM
aleekat aleekat is offline
Re: No power
Did they do a load test on the battery or just check voltage sitting?
Post back, that's what makes Forums Work.
Old 02-05-2019, 02:05 PM
Just checked it sitting.
Old 02-05-2019, 02:15 PM
Re: No power
Then I would bet if you put a voltmeter on it while cranking, probably drops under 9 volts.
Most autopart stores will do a load test for free.
Old 02-06-2019, 04:19 AM
None of the auto part stores here do load testing so I went and bought a new battery and at first when I hooked it up no power so I disconnected the negative cable and tried again and it worked. So I guess the old battery just had a dead cell I would assume. Thank you for telling me to load test the battery I was prepared to start testing any electrical component your way was much faster
