Old 01-24-2019, 06:15 PM
JRSpann JRSpann is offline
Starter?
The starter on my '98 K1500 quit working. I cleaned the battery terminals and charged the battery, but still only a solenoid click when I turn the key. Are there any other tests I need to run before I pull the starter?
Old 01-24-2019, 08:24 PM
Tech II Tech II is offline
Re: Starter?
Make sure the bat terminal connections, pos and neg, are CLEAN and TIGHT....
The same for the starter connections....
If ok, and you get bat voltage( I like to use a test light) at the purple wire to the solenoid, with the key in the crank position, then you need starter/solenoid....
The Following 2 Users Say Thank You to Tech II For This Useful Post:
JRSpann (01-25-2019)
Old 01-24-2019, 09:44 PM
Re: Starter?
OK. I'll check that in the morning. Thanks!
Old 01-25-2019, 04:30 PM
Re: Starter?
Now I'm really bumfuzzled. When I went to check the cranking voltage, it started. Nothing like an intermittent problem to mess with my mind (or what's left of it). I tried it a few times throughout the day, and it started every time.
Old 01-25-2019, 05:06 PM
777stickman 777stickman is offline
Re: Starter?
Another reason to check connections as Tech ll stated.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following 2 Users Say Thank You to 777stickman For This Useful Post:
Old 01-26-2019, 03:34 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Starter?
My 99 Yukon acted as did yours-- I wiggled the purple start wire at the solenoid connection and it started-- so take off that eyelet connection- clean it to bare metal and clean the post surface it attaches to- and grease it with some dialectric grease and be happy.
Note- it really helps that I have a remote starter- I can command a start while under the truck and don't need a helper!!
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
JRSpann (01-26-2019)
