Go Back   Automotive Forums Car Chat > Ford > Sierra
Old 01-19-2019, 02:37 PM
sierra3dr sierra3dr is offline
Fuel injector sequence
Ok fellas (and ladies),I hope everyone is ok. I've been doing some work on my DOHC (N9 engine) where I've took the engine out. As we know that means disconnecting all connectors from all sensors,and injectors. Question is,is imperative to have the correct injector loom plug connected to the correct injector? For example, mistakenly putting connector that was originally on cylinder 3 injector onto injector 4?
Thanks in advance
Paul
Sent from my Moto G (5) using Tapatalk
Old 01-19-2019, 07:09 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Fuel injector sequence
Yes it is imperative you get the correct plug back on the correct injector. If not the car will not run properly because fuel will be spraying at the wrong time.
The Following 2 Users Say Thank You to Stealthee For This Useful Post:
sierra3dr (01-20-2019)
Old 01-19-2019, 07:43 PM
thanks Stealthee. I always thought they inject on and off rapidly,as we know as pulse width,regardless when the intake valve is open or not
